at what voltages did you test?Quote:
2.4v on p5wd2-e
Kone, hmm... no chance of 400mhz+ at 3-2-2-x on those ballistix? Im thinking @ 2.6v..
which one made the diffience?Chips or PCB?Quote:
My p5wd2-e don't have mods, i think maybe can do 400mhz 3-2-2-x at 2.6vQuote:
Originally Posted by M.Beier
But it must need active radiator, Because i can feel the RAM very hot at 2.4v
Should be ChipQuote:
Originally Posted by eiceman
All test on 2.4V, At 500Mhz only can do 1m pi, I have try 500Mhz 5-4-4-X and 5-5-5-X, But it still can't stable
http://static.flickr.com/56/126240602_aed16f7805_o.jpg
http://static.flickr.com/47/126240605_24542cc315_o.jpg
http://static.flickr.com/45/126241410_6d6722724a_o.jpg
They run pretty tight:Quote:
http://img183.imageshack.us/img183/874/400mem5fg.png
And pretty fast:
http://img161.imageshack.us/img161/5954/mem5722ii.jpg
Proth: I think you post is 512mbx2 8000UL,
But blossom is ask for 4 sticks 1gb Crucial Ballistix 6400 or Corsair XMS2 6400
So far I have not seen anyone running 4gb of Ballistix at very hight fsb, but I found someone has tested running 4gb of Corsair with very impressive speed.
See the following link.
Cool, Im planning running 92mm fan on them, or watercooling...Quote:
(phasechange @ CPU, waterchilling @ GPU - and normal water @ chipset, so should be reasonable cooling mem as well with water...)
PDC21G5600+XBLK aren't D9 :(
http://wowgame.free.fr/RAM/Patriot%2...non%20D9-2.jpg
http://wowgame.free.fr/RAM/Patriot%2...%20syncmax.jpg
with 2.4v (probably can do better)
http://wowgame.free.fr/Pentium%20D%2...1%20core-2.JPG
didn't have time to test 32M, but before i primed for 2H29 without search the better timings : Prime stable 500Mhz 5-4-4-15 2.15v
I have also realized that. Does your memory even post at 3-2-2-X-X? The ones I have tested does not.Quote:
Originally Posted by overcrash86
i can boot at 266Mhz 3-2-2 but at 300 don't post, same with 2.4vQuote:
Originally Posted by crotale
I spoke with a PDP representant over mail due to RMA issues and he told me the XBL series were only made with D9 chips. Guess he's wrong :(
New updates in first post of this thread.
Still not finished, but tomorrow I'll add some more information - more memory modules, some of them will be marked as good overclocking memory with red color, on many of them will be marked what chips they use and I'll make the list more clear to read through it.
I have a lot of work, but the list will be finished tomorrow and with more help from you guys it will become bigger and bigger with time.
Greetings from Bulgaria :welcome:
just change KORSAIR MEMORY to CORSAIR MEMORY
into your first post
nice list, ill be getting some of those.
Hi guys, I need a DDR2 2GB Kit which is able to overclock to DDR2-1000
These DDR2-1000 kits are atm. to expencive so i have to buy a DDR2-800 or DDR2 667 2GB Kit.
What Kit would you choose?
Corsair, Geil, Ocz or an other one?
Regards
Dennis G. (Ger.)
bl1zZ - see the memory marked with RED color in the first post of this thread.
Hello, thanks for your answer :)
I read this thread and i couldnt see the marked memory, but after refrehing it works now =)
Regads
Dennis
What chips are in newer Ballistix and how does they perform at lowlatencies?
Cos D9 chips are out of production...
but 2x1gb will be..
cuz I just got it 2 days ago and it's fatty;)
My ballistix are CL1116M.7N
So what chips are they and how much can I expect from them?
I don't see you guys discuss anything about this brandname of this memory
Here http://www.newegg.com/Product/Produc...82E16820141064
pqi TURBO 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory - Retail
SpecificationsModel
Brand pqi
Series TURBO
Model PQI26400-2GDB
Type 240-Pin DDR2 SDRAM
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 5
Timing 5-5-5-15
Voltage 2.0V
ECC No
Buffered/Registered Unbuffered
Heat Spreader Yes
Warranty
Manufacturer Warranty Lifetime
Please tell does this memory overclockable? thanks for advices
