Originally posted by stevenmh
I realize there's no simple answer here, but what would you consider safe? I think I'm around 3.45 right now on my 3.3 line, according to Asus Probe. Is 3.6 too far? I would be happy to keep my 250 FSB and just gain the ability to run 10-2-2-3.
Also, what do you guys recommend for reading voltages? The 5 and 12 rails on Asus Probe aren't even close to what I get on my Digital Doc...the 12v rail is almost a half volt lower than the Digital Doc, while the 5v rail reads higher.
What are you using to measure DDR voltage? The OCZ Booster? Is there somewhere I can stick a multimeter? Any software monitors that will read it?
You can measure DDR voltage Pin one of any ddr slot (1st pin on the left) to ground on a multi meter.
