Dagalidis - i saw your codes in another post. how would you like to post them here? nice to see your overclock on air just for a change :cool:
thanks Flytek for that :) nice thread by the way.Quote:
Originally posted by flytek
it looks good to me. how is it performing?
btw i've hosted it for you. - zakelwe's chip below.
http://flytek.co.za/store/zakelweathlon64.jpg
I haven't got it more than stock at present due to psu problems due to poor rails and also my motherboard doesn't like the 12v 4 pin line.
Will sort that out and then update.
Regards
Andy
Finally not so stable at 2400 MHZ.....
After using CPU TOAST for stability test i found when CPU reach 51C temp freezes..... :rolleyes:
So the highest stable right now with AMD stock Cooling is 2380 - 2390 MHZ....
When upping Vcore to 1.723 then the system is more unstable due to HIGH CPU Temps....
I will receive my new EXOS clip in about 2-3 weeks and lets hope can have 2600MHZ stable.....
Btw..... Stepping details is ADA3200AEP5AP CAAKC 0334TPMW 9441535240131
Wath do you think of this config:
ABIT KV8 max 3
Athlon 64 3200+
2*256 Corsair PC3200 LL BH5
Prometeia mach 1 or 2 (RMA)
I want 2800Mhz!
I don't have my stepping available right now but...
2210Ghz with stock voltages.
Anything higher becomes unstable.
Mine does 2300 @ 1.65v stock cooling 3dmarkable I'll have to pull the cooler off later to get the codes.
I lost the OS getting this screenshot, but still.... I can't wait till ASUS fixes the bios on the K8V to handle the higher dividers
:D
impressive shot shortcircuit
This chip does 2320Mhz on Zalmaan cooler. It does this at 1.5v, at 1.65v it also does this value ..weird :) More investigation needed !Quote:
Regards
Andy
0337 XPMW is all I remember...
2505 on air.
2450 stable for 3dmark.
excellent Kunaak. it is starting to look like the later the week the better as it should be this early in the production run.
i recieved my board and chip yesterday.
chip codes:
ADA3200 AEP5AP
CAAKC 0330 MPMW
9845565240073.
the soltek K8AV2-RL has max cpu voltage of 1.7 and was not able to give prime stability at 220fsb :( . no multiplier settings and no memory timing settings to speak of. max vdimm is 2.9 which should be enough to get my bh-5's to 233fsb. it was a pleasure to set up and it does look awsome. i however have not run a personal rig at stock speed for years and i'm not about to start now. a new psu may well help the cpu. looks like i'm going to have to flog this rig and get a new combo asap.
Good luck Flytek !
Kunaak, tried your suggestion of 2-6-3-3 and still nothing oiver 2320Mhz. Interestingly at max Mhz it will do 3dmark2001 but another 1Mhz FSB, ie 10Mhz cpu it won't go into windows. I am trying a different PSU tonight.
Regards
Andy
I forgot what your running, but are you running 1:1, or have you had this problem with the 333 mode too?
my first athlon 64 :D
http://flytek.co.za/store/soltek754.jpg
I have it at 333 and 266 modes. Funnily when running 333 mode the machine bogs down to a virtual standstill, suspect something BIOS related. 266 not so bad. 400 1:1 flies.Quote:
I have never seen a chip that will do everying so close to the limit, very strange. Makes me think something is stopping it like a brick wall rather than a normal tail off in stability ..gives me hope I guess. Continuing investigations.
Regards
Andy
Still with AMD STOCK COOLING AND KEEP GOING....... :D :D
OMG 2450 MHZ but not stable 100% YET.......
I've got my A-64 3200+ with 0339 WPMW 9xxxxxxx any one can tell me about this stepping ? And i need suggestion about motherboard that match with it :) :) i preffered nForce3 chipset. I can't turn this "baby" on 'cause i don't have the mobo right now.
Keep up the good work boys.:D
tough question Benny. the chip looks like the newest stepping i've heard of so that is a very good start. the board to get is really a tough question. i hate to recomment gigabyte but that or the chaintek may be the best options. i think the most important thing to look for would be working multiplier manipulations which allow you to raise your fsb really high without pushing the chip over.
all the best. please post full codes and some results when you get it up and running
Finally i take Gigabyte GA-K8N non Pro...nForce3 150, well.... hope this board can do something :D :D i will post my result A.S.A.P :banana: :banana:
Just saw this link :-Quote:
Originally posted by zakelwe
Good luck Flytek !
Regards
Andy
http://www.e04hardware.com/Cht/kv8max3/kv8max35.htm
They have a Abit KV8 Max3 as well and ereach exactly the same 232FSB with rock stability and then no stability at 233Mhz, just like mine !
Hmmmm ...
Regards
Andy
Finally i can test my A-64.... with GA-K8N i can reach 230 FSB after make some modification on my waterblock.
Here is the compare url http://service.futuremark.com/compare?2k1=7157859
shees Benny. that's a mean score. i hope my 9500 will get near there in this rig one day
With Twinmos CH-5 and tight timing @ fsb 230 hit 22K :D :D
http://service.futuremark.com/compare?2k1=7161145
my small overclock:D
