Isn't E4x00 the budget version?
And also I thought it was single core, the Core 2 Solo.. but then that picture isn't correct.
meh i ill go with E6600
Only 2.6ghz, just put my hyper48+ and temps are now more reasonable.Quote:
Originally Posted by DsK
Anyone have any idea what temp i should stop at!? :confused:
well since we dont know how they handle temps ATM. 50-54c would be my stopping point. dont forget to watch for thermal throttling, over at ocforums ross said his cpu on the stock HS when oced was reading 65 or there about. Throttling was kicking in at those temps, was oced to 3.8ghz-3.9ghz. cant remember the voltage he used, atm.
Release date?
erm no you don'tQuote:
Originally Posted by Cooper
I flashed mine via the gigabyte program fine from F1 to F3
will it flash from cd also? I havent owned a fdd since 2000
what the data on cpu IHS?
There is none.Quote:
Originally Posted by oijkue
I flashed the bios, bought a floppy disk.
Just use @bios which is on the gigabyte cd. I downloaded F3 bios, ran @bios and that's itQuote:
Originally Posted by 775911
nice work there i think i will be getting a gigabyte mobo
wow an Allendale at 9x multi. if this chip gets a nice price it will be a nice oc'er for the gigabyte board since Allendales seem to OC higher than Conroe's
well this 6500 is suppose to be released around xmas time and some price cuts coming hopefully. i would expect to fit in the current price point of the E6400. Either that or the 6500 is going to be around the $300 range.
So what would the practical difference (as far as benchmarks) goes between this E6500 and the E4300? They both have 9x multipliers but different FSB? I'm talking OC'd benchmarks not stock benchmarks.
Interesting...
________
GAY TEEN
if im not mistaken the e4300 is also single core not dual...as far as ocing goes the e6500 will own it. i would expect the e4300's to be dud's of the higher end ones. That is unless the e4300 are really popular like the 2.4c's and they start binnning them to meet demand.Quote:
Originally Posted by Phosphate
no they're dual core as wellQuote:
Originally Posted by Evilsizer
E4300 is 7X (It should 9X)Quote:
EDIT: You are comparing 2.4GHz/1066MHz FSB with a 1.80GHz/800MHz FSB
No, 7x200 = 1400 Mhz, that doesn't make anysense...Quote:
Originally Posted by onethreehill
I thought all the core 2 duo's were going to be 266 FSB chips not half 200's and half 266. Did I miss something in the past month or what??
All the E6XXX chips are going to have 266 FSB's are they not?? The 4300is the only 200 with a 9x multi.
My memory failed me. It should be 9x200 = 1800 MhzQuote:
Originally Posted by cupholder2.0
My ds3 temp sensor is wrong too. It reports cpu idle at 63c in bios but in windows with the gigabyte overclock tool and mbm, it lists the cpu at a normal 33c idle.
3.3ghz on stock cpu volts. Ram at 2.2volts. Ram is cheap stuff, £38.50 off ebay for the pair.
I've tested the ram at 400mhz and it was fine, so hopefully i can get the cpu going a bit faster.
http://img212.imageshack.us/img212/4...rpi3iw5.th.jpg
Might be slow times because i was doing other stuff while it ran.
Also ram timings are probably crap, im a noob at ddr2.
I thought that the E6500 was an E6400 with 2MB L2 cache that is slated for release in the fourth quarter.Quote:
Yeah that would be stock but I'm talking comparing benchmarks OC'd. That e4300 should have a lot of potential for a fat OC because of that 9x multipier. (at least that is what I am thinking assuming RAM was good enough)
Could the FSB on the e4300 ever get as high as a e6500 in OC condition? ( post editted from e6300)
