I just bought 2GB KIT of Corsair XMS2 PC6400 CL4 ram. Version 6.2. Couldnt find this on the RAM list..
What chips are on them? Any chance of micron?
Specs:
PC6400
CL4-4-4-12
2.10V
Ver: 6.2
Specs:
PC6400
CL4-4-4-12
2.10V
Ver: 6.2
LOL, you are hoping for the D9.
Corsair are using 4 or 5 brands of DRAM chips for their 2x1GB XMS2. By reading the numbers written on the modules or on the package you can't determinate which chips are placed on your RAMs.
Ask the RAM guy :p
www.asktheramguy.com
I did:)
This is what I got:
So its POWERCHIP?Quote:
CM2X1024-6400C4D/C4DHX
........................XMS640X v1.X...MICRON.........64Mx8...Rev.D
........................XMS640X v2.X...PROMOS........64MX8...90nm
........................XMS640X v3.X...ELPIDA..........64MX8...Rev.H
........................XMS640X v4.X...QIMONDA.......64MX8...Rev.C
........................XMS640X v6.X...PSC..............128Mx8
How good is that compared to, like micron d9gct or gkx?
Roon, u could update DDR2 ramlist with this one, revision 6.2 CMX2 Corsair product, having Powerchip!
Hmm... probably its my bad, but cant find on the list, still :)
http://ramlist.ath.cx/ddr2/
On this list there is still no 6.2 rev XMS2 with CL4 2.1V powerchip:rolleyes:
Powerchip is awesome chip, too. As far as I knew, they widely used fo 4gb kit
Buffalo Fierstix's 1gig pc6400 do 1200 eazly at 2.1volt at cas 5
aren't there any 4gb kit that are microns?
see i have 2x1gb microns & was planning to upgrade into 2x2gb but all i can find are powerchips...would changing my microns for psc be a bad move?
4G (2x2G) equipped with D9s ? no ... ;)
Only in case you buy 4 x 1G D9s ...
Just buy a nice 2x2G kit, most of them hit ~950-1000MHz @ CL5 anyway ... :)
thanks George_o/c!
Elpida. Same for the 4-4-4-15 revision 2 dimms. Low bandwidth, high latency, little OC headroom but reliable at 2.0V. Increasing voltage beyond 2.0V does little.Quote:
OCZ DDR2 PC2-6400 Platinum Enhanced Latency XTC 2.1V 800@4-5-4-15 chips???
:/Quote:
I've been searching for an updated list. ICs are changing. Been buying Tracers, but Crucial is selling crap now. I'm looking for buying with the possibilty of D9GKX's. Any suggestions?
