Yes, it's easy, there is no wonders in electronics, only physics laws :) Try with 10k VR.
***Bump*** :)
I'm trying to get a nice power source that gives 2-3 volts. I could make one myself, but that's to difficult. So I thought, why not sense-wire-mod the 3.3v rail to 2-3 volts. Now, upping the voltage is easy, but how do I decrease it? Is there a way? I tried really everything...
Thanks.
Having issues with this mod...
Supply is Coolermaster Real Power Pro 850W
The supply only has two sense wires, orange and red. I completed the mod exactly as describded.
Only problem now is when I turn it on its ok, and after I turn the VR's down for a long time, they must alost be at zero, the supply will just shut off at a certain point. The voltage does not rise on any of the rails before shut down, even when I turn the VR extremely slow.
Anybody know whatsup? Do the newer supplies have some built in protection that does not allow this to work?
Anybody still doing this mod?
I have the corsair hx520.. does anyone know if this needs the fixed inline?? or do I only need to add the VR to it? also this will work with only changing the 12v right.. or should I change the rest while I'm in there. just so I have it if needed.
What about new psus can you mod those to? i have the InWin 1500w and i would like to get the 12v a little higher to about 12.35v instead of 12.15v?
