Hey all you clever heads!
First. Sorry for my bad inglesh.
So to the problem. My Vapo was in a serious need of new insulation.
and i changed it with some brand new Armaflex from the old thin cr@ppy one.
And a changed the PSU from a normal old ATX 350w with 12a on the 12V line. That should be fine for a Vapo PE. But the new one is a 400W BTX ( or what it so ever is called. You know, the new ones for LGA 775 boards and so on.. Picture is added further down the page .. )
This is how it looks when the new is on :
http://alcoholic.dk/view.php?id=1195&thumb=true
Personal, it looks fine ( for a first time job :p: )
BUT!!
Know my Vapo is running like cr@p! First of all it wouldnīt start if the 20a 12V
line is connected. Only if the normalt ATX caple is connected to the Chillcontroller. If i plug the 12v line to the 12V ( as you normally do ) it just wont start, ... or, the fans startīs in about 5 secs and then the chillcontroller is the only thing there is running. It shows 48 degrees celcius ( And as far as i know there is NOT 48 degrees in Denmark right know :D ) ..
And my connection looks like this :
The ATX/BTX Caple plugged into the Normal ATX caple , you can see what i mean. For me it looks right.
http://alcoholic.dk/view.php?id=1415&thumb=true
Here is what i mean with the 12V Line, that is not connected to the ChillController.
http://alcoholic.dk/view.php?id=1417&thumb=true
_______ What could the problem be here ?? ________
The other Question, is to the insulation.
Here is the temps ive got with the new insulation. Normal it hits the -34. Know its :
http://alcoholic.dk/view.php?id=1418&thumb=true
The Evap IS cold.. but not could enough.
http://alcoholic.dk/view.php?id=1416&thumb=true
___ What is wrong? Are there air coming to the suction line? Or what is wrong?
Hope you know what i mean.
Best Regards , Rasmus.
