The Pepperpot (Old School TJ07)
Hello everyone- whoever is left here :)
A quick bit of history,
I've lurked on here since... 2009? You guys got me into computers. Particularly, the Holy Grail of computer case modding through Charles Harwood and his MillionDollarPC TJ07 builds. Ah so beautiful! So shiny! I bought my TJ07 from the now defunct ChilledPC, with the view to get it watercooled and all fancy like the big boy MuderMods. Obviously I'm a little late, because that was back in 2010 and its still dry as a bone. But not for long! Welcome to my first ever build log! :)
I've posted on a couple of other forums, but I thought it would be rude not to put this on xtremeSystems. This place was the best back in the day, certainly the most interesting build logs, which is where I used to lurk. Even if nobody sees it here, at least I've contributed.
So the plan is to * finally* re-create my very own MurderMod- style TJ07. I'm not going to lie, there's not going to be much originality here as a thousand better modders have been here before and done it all (and better). Then again, it's been so long that everyone might have forgotten what a TJ07 is..... and anyway, if nothing else this log will been in homage to all the amazing work from the MurderBox guys, MillionDollarPC, xForma, and everyone else who did a sick build in this case. Hopefully there will be some useful information for someone to find in this post- most of the xtremeSystem builds have been lost to Photobucket failures, and even my carefully collected bookmarks folder of builds on Overclocked has been nuked by the forum upgrade. Dying build logs about a long ago case.... maybe i should call this build the Coffin instead :)
So here is a quick catch-up of what I've posted elsewhere, some of it might not be 100% relevant anymore because of.... reasons (you'll see)- but its content isn't it! Soon there will be new shiny updates.
Firstly, what I've got to work with:
https://forums.extremehw.net/uploads...f2273547af.jpg
What a beauty! I'm currently running a Ryzen 5 3400g/GTX 1080/32Gb on a mini ITX board because my X99/6850k system motherboard decided to stop booting, so it looks extra tiny in this case. Check out my awesome orange Xigmatek fans! 10 years old and still going strong :D
Theres some mods been done to this by ChilledPC as well. I got the internals powdercoated, a new window cut, inverted ATX layout as i think it looks so much better in a TJ07, and a quad radiator bracket. I did a couple of tiny mods too, replacing the front bay USB ports with a little 3.5" fan controller and I also changed the front Status LED's to orange ones. Because orange is the best colour. There's a terrible hacksawed cable routing hole along the rear midplate that needs cleaning up too.
I'll be grabbing some parts from ColdZero, and maybe a midplate from MartaMod. Surprisingly, the aftermarket parts scene for this case is still going strong. A testament to how awesome this case is!
https://forums.extremehw.net/uploads...7262c14745.jpg
I apologise for the obvious neglect �� Ill make it up to you TJ07 I promise! First things first, need to move existing hardware to a new case and start the TJ07 healing process X
https://forums.extremehw.net/uploads...33ea3714ea.jpg
This buildlog is sponsored by Pepper, Financial Advisor & General Assistant, MD, BSc (Hons) She is ready to begin.
https://forums.extremehw.net/uploads...61de8273a7.jpg
Sythe Himuro's might get reused as they are so cool. We shall see.
https://forums.extremehw.net/uploads...3730672cb1.jpg
Unfortunately these guys wont. Enjoy your retirement, I will always be your biggest... fan.....
https://forums.extremehw.net/uploads...5a3b39b0d8.jpg
Venerable GTX 1080. Might end up using it for another year at this rate, if Nvidia don't pull their finger out. Maybe pigs will become airbourne and AMD will produce a competitive high end GPU! We need the competition that's for sure!
https://forums.extremehw.net/uploads...c98342e3c0.jpg
Wanted to picture this as its a very cool feature of the case. The whole tray slides out the back so you can work on it with loads of access!
https://forums.extremehw.net/uploads...b2eaf0a878.jpg
Safe and sound in another decent case- a H440 I think it is.
https://forums.extremehw.net/uploads...f3a4453240.jpg
So much room for activities! I will take it apart completely as its 99% screws (not rivets) and give it a very good clean. Very simple to take apart. Maybe that's why the aftermarket parts scene is so decent for this case?
https://forums.extremehw.net/uploads...e5a3dea338.jpg
Pepper is very sad and has been relegated to the sofa after discovering she doesn't have opposable thumbs and is therefore quite useless as an assistant. Good work Pepper.
Here's what I've rendered for the design. I found a fantastic sketchup model for the case. Everything else is from TuboSquid free files. I've modelled some little bits here and there.
https://forums.extremehw.net/uploads...c0f7cfa567.jpg
https://forums.extremehw.net/uploads...0b0888de4f.jpg
https://forums.extremehw.net/uploads...7e39720185.jpg
Yeah I know, nothing too ground-breaking, but why change 10 years worth of good ideas?
Here's the (out of date now) hardware: I will update this but until HW prices return to the land of sanity, these are workable placeholders.
CPU : Ryzen 5800
GPU: RTX 3080
RAM: 32/64GB Corsair 3200
MOBO: X570 ROG Strix-E
PSU: Silverstone Strider 1000w
Storage (If anyone cares):
O/S: 512Mb NVMe
Games: 1Tb NVMe
Media: 8Tb HDD
Projects: 4Tb HDD
Projects Backup: 4TB HDD
Adobe Projects: 1TB SSD
All I need to buy is the Games NVMe, the rest has been collected over the years. I really like having separate storage for separate things.
Here's a list of watercooling bits:
CPU Block Quantum Momentum X570-E
Reservoir EK RES X4 250 (R2.0)
Radiator EK Coolstream 480
Radiator EK Coolsteam 240
Pump Aquacomputer D5 Next
GPU Block Heatkiller 3080 (if it looks nice)
GPU Backplate Heatkiller 3080 Backplate
Coolant Mayhem's Dye & Distilled Water
All kinds of 3/8-5/8 (16mm) fittings and tubes also. And a few tools to get them bent etc etc etc.
I decided I have far too much money so I'm going to sleeve my own cables. Cablemod was pretty expensive anyway so why not go whole hog? I got a little test package the other day from MDPCx with a few items. Sample sleeves & shrink for size and colour, 15AWG wire and various crimps, connectors and terminals. Thanks to the sample bits I've decided on the sizes of sleeve and colours.
Introducing the ghetto studio for crap-tacular pictures.
https://forums.extremehw.net/uploads...0b1fa27754.jpg
So this was an unexpected contender. Stripey sleeve! I think it looks really cool, and I'd love to use it but it just wont fit into the theme for this one. Maybe next time.
https://forums.extremehw.net/uploads...c46c8eb270.jpg
After playing for a little while I've come up with
https://forums.extremehw.net/uploads...33a8613d2f.jpg
From left to right: Shade 19, Papaya Orange, and Oxide Orange. Snazzy.
I've decided to use Small XTC with transparent heatshrink. I'm going to do Lutro's heatshrinkless method. I actually decided on 17 AWG wire as I thought 15 AWG was really tricky to get into the connector when it had been sleeved. Subsequent practice has made me realise this is not the case, I was just doing it :banana::banana::banana::banana:tily. Never mind. The difference is very slight. I'm going to use white wire for the oranges and black for the Shade19 sleeve. (The right backing colour makes a huge difference. I was really surprised to see how much better the colours look on the appropriate background). Im using small XTC sleeve as it fits nicer and I like the tighter weave.
I have also received a Silverstone ST-1000 PTS. I've had one of these running for the last 10 years and it's been flawless. I was actually debating weather to keep it going for this build too, but the matter was decided for me when my other half decided to short some pins to test the Ryzen System when it was getting built. Magic Purple Smoke, goodbye PSU :(
https://forums.extremehw.net/uploads...61e3d85172.jpg
So this is the same thing as my old one, except its shorter now! It's not amazingly high rated on the PSU lists but I trust them. Also, it's a 1:1 pinout with only one split cable on the ATX 24pin, so sleeving is going to be so easy compared to others! (I hope). Anyhoo, a few days after this, a package turned up from the home of wise eldars of PC modding...
https://imgur.com/GjzilLj
As is tradition.
https://forums.extremehw.net/uploads...073640ebe3.jpg
It's Sleeving!
https://forums.extremehw.net/uploads...2243a32be6.jpg
So many goodies in here. As I've mentioned above, I've decided to use Small XTC with transparent heatshrink, on 17 AWG black/white wire.
https://forums.extremehw.net/uploads...2851d97aee.jpg
This stuff looks amazing!
https://forums.extremehw.net/uploads...8f923c83d4.jpg
My personal favourite colour- Papaya Orange.
https://forums.extremehw.net/uploads...e79f914170.jpg
This is an absolute beast! Its made my crimping so much easier. Can't recommend it enough.
https://forums.extremehw.net/uploads...1e0063f294.jpg
With its baby brother awwww bless.
https://forums.extremehw.net/uploads...5102b7b887.jpg
A whole host of connectors, crimps, terminals, p-clips. I've been practicing some crimping and after about 30 wasted ATX pins I think I've worked it out :D
https://forums.extremehw.net/uploads...298ece9079.jpg
I've started making a shorty cable. The Silverstone pinout is super simple. One split cable and after looking into it, I don't think I even need to include the double one at the back there.
https://forums.extremehw.net/uploads...f8b06b27bd.jpg
How's my Crimping? Apologies this is the best macro shot I can do without a lens. This is through a magnifying glass ahah. :)
https://forums.extremehw.net/uploads...db9a6609bd.jpg
Heatshrinkless! It's not difficult at all. (With some practice....)
https://forums.extremehw.net/uploads...eb6c7300e5.jpg
17AWG on the left, 15AWG on the right.
I got another package from Germany too!
https://forums.extremehw.net/uploads...b93f5362d4.jpg
Pepper approves!
https://forums.extremehw.net/uploads...74eb1c03c0.jpg
Post 2: Electric Boogaloo
Another package.
Author
Posted October 27, 2020
Another package.
https://forums.extremehw.net/uploads...b8e6f174cb.jpg
These arrived much sooner than I expected! This afternoon I've had a play around with all the Aquacomputer stuff.
https://forums.extremehw.net/uploads...9e0ca1499e.jpg
https://forums.extremehw.net/uploads...e48fdd6884.jpg
Sweet holy jeebus. What a total cabling nightmare! One Aquero, one Farbwerk, 3 Splitty4's, 6 Corsair QL120's and a whole load of spaghetti. At least I don't have to cook tonight! Unfortunately, the Farbwerk can only support 90 LED's per channel. As the QL-Series fans have 34 LED's each, this means 2 fans max per channel. I'm having to use one Splitty4 per 2 fans, and I've used one Farbwerk channel for LED Strips. Not included in this setup is the three in-line water temp monitors I want to include, the pump, a flow monitor and air temp sensors. I'm definitely going to have to work out how to shorten and sleeve the majority of this stuff. It's all going to have to fit in the bottom of the TJ07... somehow.... I'm going to have to build some kind of mounting setup :D
As for the Aquasuite software, it's exactly what I need. no nonsense, no fancy graphics or bull:banana::banana::banana::banana: OTT interfaces. (Looking at you, thermaltake)
https://forums.extremehw.net/uploads...325e11c478.jpg
So neat! So tidy! Individually addressable LED's with any effect and copy/pasting. Yes Please.
I didn't take into account all this Aquaero stuff in my original Sketchup file. I've also got a D5 instead of a DDC, so new pump placements required.
https://forums.extremehw.net/uploads...53087d3ba0.jpg
The DDC is already really squished in there! I spent a while throwing about the Aquacomputer parts in this section but there's no chance they're going to fit.
Design MKII- The D5 is too big to fit in-between the rads, and there needs to be space for the cables to run too. This new layout keeps the buttons on the D5 easy to reach and I can get a wider 240mm rad now if I want! This hasnt solved the Aquero stuff needing a home though, sooooo...
https://forums.extremehw.net/uploads...6e21e2713e.jpg
https://forums.extremehw.net/uploads...24b92ebf19.jpg
Before & after ^^ - I've moved the Himuro Drive days to a vertical config. I've and created a little mount for the monitoring stuff which is going to be super simple to knock up!
https://forums.extremehw.net/uploads...e1741e89ed.jpg
It will be super easy to access through the front panel.
https://forums.extremehw.net/uploads...f9c740e509.jpg
Moving the Himuro Drives to a vertical config makes the inside of the case look nicer too! They fill the space almost perfectly, and give me loads more room- the space between the GPU/RES/Himuro has gone from about 5mm to 5cm. Should make life easier all round. As long as all my measurement are correct.... still has to pass the IRL test :)
