DeepCool PX-G ATX 3.0 power supplies with 12VHPWR connector
DeepCool, is proud to announce PX-G, its first power supply series to receive full ATX 3.0 compatibility. The DeepCool PX-G series includes 850W, 1000W and 1200W power supplies.
https://i.postimg.cc/MH7pD3cz/Screen...-06-113904.jpg
ATX 3.0 Ready
The PX-G is an ATX 3.0 certified power supply that meets the latest ATX 3.0 standard. With a dedicated 12VHPWR, 2 EPS, and 3 PCI-e ports, the PX-G provides stable power for a wide range of components. Whether you have a legacy or next-generation PC, the PX-G will support any modern GPUs, giving you endless options for customization.
https://i.postimg.cc/cJv1jLK9/Screen...-06-113924.jpg
One of the most notable features of the PX-G is its dedicated PCI-e Gen 5.0 power cable (12VHPWR) and 5 EPS/PCI-e ports. This enables the power supply to deliver up to 300% TGP and 200% Total System Power excursions, ensuring stable and consistent power for even the most power-hungry components. The PX-G also boasts a dual 105C Japanese main capacitor topology that enables the power supply to keep the hold-up time to ≥ 16ms under full load. Additionally, the PCI-e Gen 5.0 12VHPWR cable utilizes 16AWG wires and provides up to 600W for power-hungry GPUs.
DeepCool PX-G power supplies are cooled by a 135mm fluid dynamic bearing fan. The fan can be switched to a "smart" mode of operation, in which the speed of rotation will be adjusted depending on the temperature of the components. When the load on the PSU is low, the fan will stop completely.
https://i.postimg.cc/Fz7xkc1b/Screen...-06-114221.jpg
All DeepCool PX-G power supplies are 80 Plus Gold certified. This means that the efficiency of the PSU reaches 90% at half load. In addition, the DeepCool PX-G series can withstand short-term system power surges up to two times. Also, power supplies are equipped with six main types of protection - from short circuit, from excess power, from excess / undervoltage, from overcurrent and from overheating.
https://i.postimg.cc/xd1tMqxd/Screen...-06-114315.jpg
The cost of new products starts at €159.99.
PX850G-MSRP : €159.99 Incl. VAT
PX1000G-MSRP : €179.99 Incl. VAT
PX1200G-MSRP : €219.99 Incl. VAT
All models receive a full 10-year manufacturer's warranty.
https://i.postimg.cc/wMpWt2nC/Screen...-06-114837.jpg
