Help me build my dream video editing & storage machine
Hi hopefully this is the proper part of the forum to post this into
First I have to confess that I build my last pc over 6 years ago and I since then did not read up or follow any computer magazines or test. You could easy say that Im a noob. BUT I have a once in a lifetime opportunity to build a video encoding/ storage server machine and my work will cover the costs.
From the little reading I did I think that the PC-D8000 case from Lian Li would be perfect for my needs... http://www.lian-li.com/v2/en/product...s_index=62&g=f
The machine needs as much cpu power as possible for video encoding and the plan is to have a 20-25 hdd raid. I know that Id like a water cooled system with a Intel i7 extreme. But i really dont know wich components would be the best for my needs and wich components fit well together.... I need the raid and the cpu encoding power for work but if those criteria are filled and if the case allows It I'd pitch in for a sli system myself and just use the system for work & play.
Open to any suggestions
