Help me find a new cpu heatsink
Im looking to upgrade to skt 1150 from 775, my old xp-120 has has earned its retirement (i may try and mod it to fit 1150 but it might not perform how i like on these new hotter cpus, convince to mod it to fit if you think its a good idea).
I dont care about noise i use industrial 12cm dc fans in my case any way.
I dont care about looks.
I dont care about weight or price.
I would prefer top down style as I have two industrial 12cm dc fans blowing down 1 over cpu and 1 over vga located towards the rear end of the case.
My case lies flat on it its side I have two 12cm industrial fans blowing in, 1 14cm blowing in across the hdd bay and 1 industrail 12cm blowing out on the rear and currently on my 775 I have 1 12cm industrails fan mounted on the the thrmalright xp-120
but if you can sell me on a horizontal style like appears to be all the rage now, i will listen. I like the down style as it helps cool the mobo vrma and ram and i fear my case fan orintaion may might not work with horizontal type cpu coolers
I cant seem to find much in the down style range
Im lookign at a GA-Z87X-UD3H mobo and a 4670k cpu and plan on 24/7 stable oc like i currently have on my e8500@4.0GHz
edit: ignore my sig way out of date
